Samsung Galaxy Tab 4 7.0 Speaker Replacement
  1. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Starting at any corner, insert the pry tool between the chrome screen frame and black phone housing.
    • Slide the pry tool around the tablet while applying force to pry the screen away from the phone housing.
  2. Samsung Galaxy Tab 4 7.0 Speaker Replacement: step 2, image 1 of 1
    • Carefully separate the rear housing from the front panel assembly.
  3. Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: step 3, image 1 of 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement, Speaker: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • In order the speaker connection, you must first peel back part of the surrounding water gasket.
    • With the tweezers, grab the overhanging corner and peel the gasket back slowly.
    • If you look closely, you will see the two slots indicated. Use the tweezers to lift this portion of the connection away from these slots.
  4. Samsung Galaxy Tab 4 7.0 Speaker Replacement: step 4, image 1 of 2 Samsung Galaxy Tab 4 7.0 Speaker Replacement: step 4, image 2 of 2
    • Now you should be able to lift the speaker out of it's small fitting with the tweezers.
2 other people completed this guide.
Aubrey Goodwin
2,700 Reputation
3 Guides authored
USF Tampa, Team 1-3, Remmell Fall 2015 Member of USF Tampa, Team 1-3, Remmell Fall 2015
USFT-REMMELL-F15S1G3
4 Members
12 Guides authored
2 Comments
Where can I order the new speaker?
Dorrie Stotko - Reply
This would be better if it were a YouTube video so we could actually see it being done.
robinmyrobin - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 3,952
