Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement
  1. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement, Motherboard: step 1, image 1 of 2 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement, Motherboard: step 1, image 2 of 2
    • Insert the plastic opening tool into the gap between the device frame and the back panel on any side of the device.
    • Slide the opening tool around the edges of the device to disconnect the back panel from the frame.
  2. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 2, image 3 of 3
    • Carefully remove the back panel from the frame of the device.
  3. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 3, image 3 of 3
    • Using a Phillips #00 Screwdriver, remove the five 4 mm screws connecting the motherboard to the frame of the device.
  4. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Use the plastic opening tool to unlock the battery wire from the motherboard by flipping-up the small retaining flap.
    • Use the tweezers to carefully remove the battery wire from the motherboard by pulling it away from the retainer flap.
  5. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 5, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 5, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 5, image 3 of 3
    • Use the plastic opening tool to unlock the wire on the narrow section of the motherboard by flipping-up the retaining flap.
    • Use the tweezers to carefully remove the wire from the motherboard by sliding it away from the retaining flap.
  6. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 6, image 3 of 3
    • Disconnect the wire near the bottom of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  7. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 7, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 7, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 7, image 3 of 3
    • Disconnect the wire near the top of the motherboard by placing the plastic opening tool under the edge of the connector to flip it up.
  8. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 8, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 8, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 8, image 3 of 3
    • Gently remove the motherboard from the frame of the device by grabbing the top and bottom ends and pulling it toward you.
    • Several plastic tabs keep the motherboard in place, so you will have to apply some force.
  9. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement, Vibrator: step 9, image 1 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement, Vibrator: step 9, image 2 of 3 Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement, Vibrator: step 9, image 3 of 3
    • Insert the pointed tip of the nylon spudger between the vibrator and the board.
    • Carefully push the vibrator out and away from the board.
  10. Samsung Galaxy Tab 4 7.0 Sprint Vibrator Replacement: step 10, image 1 of 1
    Buy
    • Using the tweezers, pull the vibrator off the board.
Valentina Franco
434 Reputation
4 Guides authored
Cal Poly, Team 18-3, Forte Fall 2016 Member of Cal Poly, Team 18-3, Forte Fall 2016
CPSU-FORTE-F16S18G3
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 14
All Time: 498
