Samsung Galaxy Tab 4 8.0 Verizon Display Replacement
  1. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: step 1, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: step 1, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Motherboard: step 1, image 3 of 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the metallic rectangular connector from its socket on the mother board.
  2. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 2, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 2, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 2, image 3 of 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold rectangular connector from its socket on the mother board.
  3. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 3, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 3, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 3, image 3 of 3
    • Slightly apply pressure and move the blue plastic opening tool downwards to pop the gold square connector from its socket on the mother board.
  4. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 4, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 4, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 4, image 3 of 3
    • Using the spudger gently wedge the blue wire out of its compartment.
  5. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 5, image 1 of 1
    • Remove two 2 mm #000 Phillips screws securing the metallic charger port cover to both the logic board and the front panel.
  6. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 6, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 6, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Squeeze the metal charger port cover piece with the tweezers to gently lift it from it's place.
  7. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 7, image 1 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 7, image 2 of 3 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 7, image 3 of 3
    • Carefully insert the flat end of the blue plastic opening tool under the black plastic fastener and lift.
    • Rotate your tablet counter clockwise to facilitate the process.
  8. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 8, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 8, image 2 of 2
    • Squeeze the golden cable with the tweezers and gently pull the cable to the left to free the end of the golden cable.
    • The golden cable is delicate so use gentle force.
  9. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 9, image 1 of 1
    • Remove three 2 mm #000 Phillips screws securing the mother board to the front panel.
  10. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 10, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 10, image 2 of 2
    • Using your hands, hold the opposite ends of the mother board corners, and lift.
  11. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement, Display: step 11, image 1 of 1
    • Insert an opening pick in between the display screen and the display frame.
  12. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 12, image 1 of 1
    • Wedge four of the opening picks in between the display screen and the device backing on all four corners.
  13. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 13, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 13, image 2 of 2
    • Wedge the Jimmy between the display and the device backing at a corner.
    • Cut through the adhesive that is securing the screen to the device on all four sides.
  14. Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 14, image 1 of 2 Samsung Galaxy Tab 4 8.0 Verizon Display Replacement: step 14, image 2 of 2
    • Once the display is completely disconnected from the device gently remove it without touching the screen which lies underneath.
2 other people completed this guide.
One Comment
Umm….how do you remove the rear cover?
Gregg Stanley - Reply
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 499
