Samsung Galaxy Tab 7.7 Battery Replacement
  1. Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: step 1, image 1 of 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: step 1, image 2 of 3 Samsung Galaxy Tab 7.7 Battery Replacement, Opening the tablet: step 1, image 3 of 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Battery Replacement, Disconnecting the battery: step 2, image 1 of 1
    • Detach the five wire connection of the battery from the motherboard. You will need to gently insert a flat head screwdriver under the connector, and using left to right motion with your wrist, create a small space separating the connector from its connection. Gradually make the space wider until the connector pops out of its socket.
  3. Samsung Galaxy Tab 7.7 Battery Replacement, Unscrewing the battery: step 3, image 1 of 1
    • Remove the 6 screws securing battery.
  4. Samsung Galaxy Tab 7.7 Battery Replacement, Replacing the battery: step 4, image 1 of 1
    • Remove the original battery, replace it with a new one.
8 other people completed this guide.
Stephanie Wong
973 Reputation
5 Guides authored
USF Tampa, Team 13-2, Staggers Fall 2014 Member of USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 7,814
