Samsung Galaxy Tab 7.7 Flex cable Replacement
  1. Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: step 1, image 1 of 3 Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: step 1, image 2 of 3 Samsung Galaxy Tab 7.7 Flex cable Replacement, Opening the tablet: step 1, image 3 of 3
    • Using the prying tool, pry the silver binding from around tablet from glass edge. You will need to go around the device several times applying some force before it comes off.
  2. Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: step 2, image 1 of 2 Samsung Galaxy Tab 7.7 Flex cable Replacement, Disconnecting the flex cable: step 2, image 2 of 2
    • Unsnap all the ribbon cables from the flex cable.
  3. Samsung Galaxy Tab 7.7 Flex cable Replacement, Unscrewing the flex cable: step 3, image 1 of 1
    • Remove the screws securing the flex cable to the chassis.
  4. Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: step 4, image 1 of 2 Samsung Galaxy Tab 7.7 Flex cable Replacement, Removing the flex cable: step 4, image 2 of 2
    • Remove the original flex cable and replace it with the flex cable.
Stephanie Wong
973 Reputation
5 Guides authored
USF Tampa, Team 13-2, Staggers Fall 2014 Member of USF Tampa, Team 13-2, Staggers Fall 2014
USFT-STAGGERS-F14S13G2
4 Members
9 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 835
