Samsung Galaxy Tab 8.9 Battery Replacement
  1. Samsung Galaxy Tab 8.9 Battery Replacement, Battery: step 1, image 1 of 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  2. Samsung Galaxy Tab 8.9 Battery Replacement: step 2, image 1 of 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  3. Samsung Galaxy Tab 8.9 Battery Replacement: step 3, image 1 of 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  4. Samsung Galaxy Tab 8.9 Battery Replacement: step 4, image 1 of 1
    • Use your hands to open the back cover.
  5. Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: step 5, image 1 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: step 5, image 2 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove Green Tape: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  6. Samsung Galaxy Tab 8.9 Battery Replacement: step 6, image 1 of 2 Samsung Galaxy Tab 8.9 Battery Replacement: step 6, image 2 of 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  7. Samsung Galaxy Tab 8.9 Battery Replacement: step 7, image 1 of 3 Samsung Galaxy Tab 8.9 Battery Replacement: step 7, image 2 of 3 Samsung Galaxy Tab 8.9 Battery Replacement: step 7, image 3 of 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  8. Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: step 8, image 1 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: step 8, image 2 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Disconnect Battery from MotherBoard: step 8, image 3 of 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  9. Samsung Galaxy Tab 8.9 Battery Replacement: step 9, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  10. Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: step 10, image 1 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: step 10, image 2 of 3 Samsung Galaxy Tab 8.9 Battery Replacement, Remove the Battery: step 10, image 3 of 3
    • Use a spudger to lift up and separate the battery from its housing.
4 other people completed this guide.
Dan D
160 Reputation
1 Guide authored
USF Tampa, Team 11-4, Blackwell Fall 2014 Member of USF Tampa, Team 11-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G4
4 Members
10 Guides authored
One Comment
Step 8 Clearer to say:
Insert the spudger under the red, black, and white cables to pry up the battery connector and detach it and the battery from the motherboard.
Paul Jackson - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,653
