Samsung Galaxy Tab 8.9 Headphone Jack Replacement
  1. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Insert Opening tool: step 1, image 1 of 1
    • Insert a plastic opening tool between the back cover and screen of the Samsung Galaxy Tab 8.9 (as indicated in the photograph).
  2. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Insert second tool: step 2, image 1 of 1
    • Insert a second plastic opening tool 6 cm (~2.4 inches) away from the first tool.
  3. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 3, image 1 of 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover.
  4. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 4, image 1 of 1
    • Using your hands, remove the back cover.
  5. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Battery: step 5, image 1 of 1
    • Insert a plastic opening tool between the back cover and the screen of the Samsung Galaxy Tab 8.9.
  6. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 6, image 1 of 1
    • 6 cm [2 in] away from the first plastic opening tool, insert a second plastic opening tool between the back cover and the screen.
  7. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 7, image 1 of 1
    • Slide the second plastic opening tool along the edge of the device to separate the back cover from the screen.
  8. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 8, image 1 of 1
    • Use your hands to open the back cover.
  9. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: step 9, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: step 9, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove Green Tape: step 9, image 3 of 3
    Tool used on this step:
    Buy
    • Use tweezers to peel up the green tape located on top of the two flexible ribbon cables.
  10. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 10, image 1 of 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 10, image 2 of 2
    • Insert a spudger under the orange tab.
    • Gently pry up the tab to disconnect the black flexible ribbon cable from the motherboard.
  11. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 11, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 11, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 11, image 3 of 3
    • Carefully pull out the yellow flexible ribbon cable to disconnect it from the motherboard.
  12. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: step 12, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: step 12, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Disconnect Battery from MotherBoard: step 12, image 3 of 3
    • Insert the spudger under the red, black, and white cables.
    • Pry up and detach the battery from the motherboard.
  13. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 13, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the nine 1 mm screws located around the battery.
  14. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: step 14, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: step 14, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Remove the Battery: step 14, image 3 of 3
    • Use a spudger to lift up and separate the battery from its housing.
  15. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: step 15, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: step 15, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Motherboard: step 15, image 3 of 3
    • Locate the motherboard and 5 connectors on it.
    • Pry up and detach the connector from the motherboard using the flat edge of the spudger.
    • Repeat for the 4 remaining connectors.
  16. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 16, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 16, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 16, image 3 of 3
    • Using the Phillips #00 screwdriver, unscrew the 3 screws (1mm) that are located near:
    • Camera
    • Power and volume buttons
    • Tilt sensor
  17. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 17, image 1 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 17, image 2 of 3 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 17, image 3 of 3
    • Using the flat edge of the spudger, pry and lift up the motherboard.
  18. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 18, image 1 of 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 18, image 2 of 2
    • Pull away the motherboard from the housing.
  19. Samsung Galaxy Tab 8.9 Headphone Jack Replacement, Headphone Jack: step 19, image 1 of 1
    • Using a Phillips #00 screwdriver, unscrew the 2 screws (3mm).
  20. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 20, image 1 of 2 Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 20, image 2 of 2
    • Remove two metal support brackets.
  21. Samsung Galaxy Tab 8.9 Headphone Jack Replacement: step 21, image 1 of 1
    • Lift headphone jack assembly.
Eric Bird
543 Reputation
5 Guides authored
IUPUI, Team S4-G2, Harley Spring 2017 Member of IUPUI, Team S4-G2, Harley Spring 2017
IUPUI-HARLEY-S17S4G2
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 141
