Samsung Galaxy Tab A 10.1 Back Panel Replacement
  1. Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab A 10.1 Back Panel Replacement, Back Panel: step 1, image 2 of 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Back Panel Replacement: step 2, image 1 of 2 Samsung Galaxy Tab A 10.1 Back Panel Replacement: step 2, image 2 of 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
9 other people completed this guide.
Isabella Li
2,376 Reputation
7 Guides authored
Cal Poly, Team S15-G6, Livingston Fall 2017 Member of Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Members
26 Guides authored
One Comment
Why need to remove cables when only the back has to be replaced ?
nabe_03 - Reply
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 92
All Time: 11,949
