Samsung Galaxy Tab A 10.1 Battery Replacement
Video Overview
  1. Samsung Galaxy Tab A 10.1 Battery Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab A 10.1 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Battery Replacement: step 2, image 1 of 2 Samsung Galaxy Tab A 10.1 Battery Replacement: step 2, image 2 of 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Battery Replacement, Disconnecting the battery: step 3, image 1 of 1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Tab A 10.1 Battery Replacement: step 4, image 2 of 2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Battery Replacement: step 5, image 1 of 3 Samsung Galaxy Tab A 10.1 Battery Replacement: step 5, image 2 of 3 Samsung Galaxy Tab A 10.1 Battery Replacement: step 5, image 3 of 3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Battery Replacement, Battery removal: step 6, image 1 of 2 Samsung Galaxy Tab A 10.1 Battery Replacement, Battery removal: step 6, image 2 of 2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
46 other people completed this guide.
Isabella Li
2,376 Reputation
7 Guides authored
Cal Poly, Team S15-G6, Livingston Fall 2017 Member of Cal Poly, Team S15-G6, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G6
4 Members
26 Guides authored
9 Comments
Used this guide up until the disconnecting of the battery in order to fix the black screen of death. Very very helpful. Thank you.
Steffan Syd Apel - Reply
If you have my kind of bad luck — where the latch for the battery flex cable connector sticks to the tape when you remove the tape, and then it will not snap back into place — don’t worry about it too much, because the connector tension will hold the flex cable in place. Just put the tape back over the top as directed.
Richard Ekblaw - Reply
Why does it say you need a heat gun?
Geert Pante - Reply
To loosen the adhesive. A hair dryer works well too
qaisraja22 -
how to calibrate the new battery?
when device switched off due to 0% of battery - there is impossible to boot it even with charging. there is required to open a tablet and charge the battery from another source.
Алексей Хейдоров - Reply
Past 24 Hours: 12
Past 7 Days: 84
Past 30 Days: 423
All Time: 64,817
