Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement
  1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: step 1, image 1 of 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: step 1, image 2 of 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 2, image 1 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 2, image 2 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 2, image 3 of 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 3, image 1 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 3, image 2 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 3, image 3 of 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: step 4, image 1 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: step 4, image 2 of 3 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: step 4, image 3 of 3
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
    • Use the plastic opening tool to remove the motherboard from the case.
  5. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 5, image 1 of 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while prying upwards until the screen separates from the bezel.
    • The screen may crack during this process so be wary of broken glass.
    • Applying heat may be necessary to loosen the glue.
4 other people completed this guide.
Guneet Bawa
688 Reputation
4 Guides authored
UW Tacoma, Team S1-G5, Liner Spring 2018 Member of UW Tacoma, Team S1-G5, Liner Spring 2018
UWT-LINER-S18S1G5
5 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 3,338
