Samsung Galaxy Tab A 7.0" Headphone Jack Replacement
  1. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement, Headphone Jack: step 1, image 1 of 1
    • Using the plastic opening tool, starting at any corner on the tablet, insert the tool between the back panel and the front panel.
    • Slide tool around the tablet to unlock the panels from one another.
  2. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 2, image 1 of 2 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 2, image 2 of 2
    • Carefully remove the back panel from the front panel.
    • The inner components of the tablet will now be exposed.
  3. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 3, image 1 of 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 3, image 2 of 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 3, image 3 of 3
    • Remove the two Phillips head screws attaching the auxiliary port to the plastic frame using a P000 screwdriver.
    • Remove the four Phillips head screws attaching the motherboard to the plastic case using a P000 screwdriver.
  4. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers disconnect the headphone jack connector from the motherboard.
  5. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 5, image 1 of 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 5, image 2 of 3 Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 5, image 3 of 3
    • Using tweezers, carefully lift up the motherboard.
    • Using tweezers, remove the metal jacket holding the headphone jack in place by grabbing the left corner where there is a recess to grab it.
    • There is a light adhesive holding the metal jacket down. You may have to pull slightly harder to get this off.
  6. Samsung Galaxy Tab A 7.0" Headphone Jack Replacement: step 6, image 1 of 1
    • Remove the auxiliary port from the case.
5 other people completed this guide.
Bradley Watson
1,079 Reputation
4 Guides authored
USF Tampa, Team 5-4, Passmore Spring 2017 Member of USF Tampa, Team 5-4, Passmore Spring 2017
USFT-PASSMORE-S17S5G4
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 59
All Time: 3,997
