Samsung Galaxy Tab A 9.7 Battery Replacement
  1. Samsung Galaxy Tab A 9.7  Battery Replacement, Back Cover: step 1, image 1 of 1
    • Insert a metal spudger between the back case and the screen of the device.
    • The back cover is attached to the device by a series of snaps. The snaps are positioned about an inch from each other.
    • Move the spudger along the perimeter of the device while it is in between the back case and the screen to open each snap.
    • There will be an audible click every time a snap releases.
  2. Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: step 2, image 1 of 2 Samsung Galaxy Tab A 9.7  Battery Replacement, Battery: step 2, image 2 of 2
    • Remove the eleven #000 Phillips 2.8mm screws that hold the battery in place.
  3. Samsung Galaxy Tab A 9.7  Battery Replacement: step 3, image 1 of 2 Samsung Galaxy Tab A 9.7  Battery Replacement: step 3, image 2 of 2
    • Place one hand on the battery and grasp the outer edge of the device with the other hand.
    • Flip the device over so that the battery falls over and onto your hand.
  4. Samsung Galaxy Tab A 9.7  Battery Replacement: step 4, image 1 of 2 Samsung Galaxy Tab A 9.7  Battery Replacement: step 4, image 2 of 2
    • Pull the battery out until it is only connected to the device by the black, yellow, and red connectors.
  5. Samsung Galaxy Tab A 9.7  Battery Replacement: step 5, image 1 of 2 Samsung Galaxy Tab A 9.7  Battery Replacement: step 5, image 2 of 2
    • Hold the battery and grip the wires with your thumb and finger.
    • Pull the wires away from the device to remove the white connector from the black socket.
    • Lift the battery away from the device.
13 other people completed this guide.
Paulina Nguyen
982 Reputation
6 Guides authored
Cal Poly, Team S1-G3, Livingston Spring 2017 Member of Cal Poly, Team S1-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S1G3
1 Member
12 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 62
All Time: 11,210
