Samsung Galaxy Tab E 8.0 Front Camera Replacement
Christian Bloemhof
Christian Bloemhof and 4 other contributors
Last updated on May 7, 2024
5 - 10 minutes
Easy
Introduction
Go to step 1
The front camera of the Samsung Galaxy Tab E 8.0 can be damaged if the camera is struck by a hard object. This guide shows how to replace the tablet's front camera which is attached to the motherboard.
Tools
  1. Samsung Galaxy Tab E 8.0 Front Camera Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab E 8.0 Front Camera Replacement, Back Panel: step 1, image 2 of 2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Front Camera Replacement, Front Camera: step 2, image 1 of 3 Samsung Galaxy Tab E 8.0 Front Camera Replacement, Front Camera: step 2, image 2 of 3 Samsung Galaxy Tab E 8.0 Front Camera Replacement, Front Camera: step 2, image 3 of 3
    Tool used on this step:
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
2 other people completed this guide.
Christian Bloemhof
1,120 Reputation
7 Guides authored
Cal Poly, Team S13-G4, White Fall 2018 Member of Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 16
All Time: 334
