Samsung Galaxy Tab E 8.0 Motherboard Replacement
  1. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Panel: step 1, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Use the iFixit Opening Tool to pry off the back case, moving the tool around the screen.
    • Make sure the device is off and the SD card is removed before taking off the back casing.
  2. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Camera: step 2, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Back Camera: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Use the tweezers to lift the switch connecting the back camera to the motherboard.
    • Use your hand to remove the back camera from the motherboard.
  3. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: step 3, image 1 of 3 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: step 3, image 2 of 3 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Front Camera: step 3, image 3 of 3
    Buy
    • Use the tweezers to lift the switch connecting the front camera to the motherboard.
    • Remove the front camera from the motherboard by lifting with the tweezers.
  4. Samsung Galaxy Tab E 8.0 Motherboard Replacement, Motherboard: step 4, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement, Motherboard: step 4, image 2 of 2
    Buy
    • Use the tweezers to flip the switch on the bottom of the strap that goes over the battery.
    • Release the strap from the switch by lifting the strap with your hand.
  5. Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 5, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 5, image 2 of 2
    • Use the tweezers to flip the switch that connects the top of the strap to the motherboard.
    • Lift the top end of the strap with your hand and remove the strap completely from the device.
  6. Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 6, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 6, image 2 of 2
    • Use the tweezers to flip the switch of the connector.
    • Lift the connector from the motherboard.
    • This connector does not come completely off, but disconnects from the motherboard.
  7. Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 7, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 7, image 2 of 2
    • Use the tweezers to flip the switch of the blue connector on the motherboard.
    • This switch can detach from the device, but just needs to disconnect from the motherboard.
    • Ensure the blue ribbon cable is not under the motherboard upon reassembly.
  8. Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 8, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 8, image 2 of 2
    • Use the tweezers to flip the switch of the connector that runs from the battery to the motherboard.
  9. Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 9, image 1 of 2 Samsung Galaxy Tab E 8.0 Motherboard Replacement: step 9, image 2 of 2
    • Use a JIS #00 screwdriver to remove the six 4.5mm screws at the top of the motherboard.
    • Lift the motherboard with your hand to detach the motherboard from the device.
Christian Bloemhof
1,102 Reputation
7 Guides authored
Cal Poly, Team S13-G4, White Fall 2018 Member of Cal Poly, Team S13-G4, White Fall 2018
CPSU-WHITE-F18S13G4
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 2,205
