Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement
  1. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement, Back Casing: step 1, image 1 of 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 2, image 1 of 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 2, image 2 of 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 2, image 3 of 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 3, image 1 of 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 3, image 2 of 3 Samsung Galaxy Tab E 9.6 Verizon Back Casing Replacement: step 3, image 3 of 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
Dave Dorzback
626 Reputation
4 Guides authored
USF Tampa, Team 1-4, Cagle Fall 2016 Member of USF Tampa, Team 1-4, Cagle Fall 2016
USFT-CAGLE-F16S1G4
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 2,707
