Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement
Nicholas Nolan
Nicholas Nolan and 4 other contributors
Last updated on May 7, 2024
15 - 20 minutes
Moderate
Introduction
Go to step 1
This replacement guide will show you how to replace the motherboard in your Samsung Galaxy Tab E Lite 7 Kids. You will need to follow the instructions carefully as to not damage any fragile components in your tablet.
Tools
Show more…
  1. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: step 1, image 1 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: step 1, image 2 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Rear Case: step 1, image 3 of 3
    • Make sure the device is turned off before attempting to disassemble it.
    • Using a plastic opening tool, wedge in the seam between the screen and the case.
    • Rock the tool by moving it towards and away from the middle of the screen, trying to separate the tape holding the screen and case together.
  2. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 2, image 1 of 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 2, image 2 of 2
    • After separating the latches holding the screen and case together, slowly take the screen off the case.
  3. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: step 3, image 1 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: step 3, image 2 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Use the plastic opening tool to lift up the black ZIF (zero insertion force) connector.
    • Use your hands to pull the black cable out of its slot.
  4. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 4, image 1 of 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to lift the ZIF (zero insertion force) connector holding the ribbon cable.
    • Pull out the battery's ribbon cable.
  5. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 5, image 1 of 2 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 5, image 2 of 2
    • Use the plastic opening tool to lift up the latch to the ribbon cable.
    • Remove the ribbon cable from the connector.
  6. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 6, image 1 of 1
    • Remove the seven 4mm PH000 screws holding the motherboard in place.
  7. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 7, image 1 of 1
    • Use the plastic opening tool to pry up the tab holding the motherboard in place.
  8. Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 8, image 1 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 8, image 2 of 3 Samsung Galaxy Tab E Lite 7 Kids Motherboard Replacement: step 8, image 3 of 3
    Tool used on this step:
    • Use the precision tweezers to remove the black plastic corner on top of the motherboard.
    • Use the plastic opening tool to pull the motherboard out of the case.
3 other people completed this guide.
Nicholas Nolan
805 Reputation
5 Guides authored
USF Tampa, Team S19-G2, Hoffman Spring 2017 Member of USF Tampa, Team S19-G2, Hoffman Spring 2017
USFT-HOFFMAN-S17S19G2
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 1,083
