Samsung Galaxy Tab S 8.4 Micro USB Port Replacement
  1. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Back Cover: step 1, image 2 of 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: step 2, image 1 of 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: step 3, image 1 of 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: step 4, image 1 of 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement, Micro USB Port: step 4, image 2 of 2
    • Remove the two 4 mm Phillips #000 screws securing the micro USB port.
  5. Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: step 5, image 1 of 2 Samsung Galaxy Tab S 8.4 Micro USB Port Replacement: step 5, image 2 of 2
    • Using the plastic opening tool, disconnect the charge port from the motherboard.
    • Once disconnected, lift to remove the charging port.
32 other people completed this guide.
Trent Chapman
1,378 Reputation
3 Guides authored
Cal Poly, Team 12-15, Maness Fall 2015 Member of Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Members
12 Guides authored
6 Comments
It is so amazing and it works!
alva chan - Reply
Thanks a lot!
You make me a big economy by doing this myself with YOUR instructions !
Raphael
refelo123 - Reply
What model number is this device specifically? It says WiFi, but I have the same one from a network carrier. Would this charging port work for that? Model sm-707v is the one that I have.
tailoredtoteach - Reply
Thanks for the instructions, it looks simple , so I ordered the docking assembly and I replace it by myself.
You saved me a lot of money, thanks again!
wim-zelf - Reply
With these instructions I ordered part from Amazon and replaced charging port and tablet charges again. Thanks!
Philip Holly - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 51
All Time: 15,348
