Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement
  1. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: step 1, image 1 of 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Back Cover: step 1, image 2 of 2
    • Place the plastic opening tool between the face of the display and rim of the back cover of the device.
    • Move the plastic opening tool in a downward motion until you see separation between the tablet and back cover.
  2. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: step 2, image 1 of 1
    • By sliding the plastic opening tool around the rim of the device, carefully continue to pry apart the screen and back cover.
    • Try to separate evenly on all sides until the screen detaches from the device backing completely.
    • If this is the first time removing the back cover, it will be rather difficult to separate it from the tablet.
  3. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement: step 3, image 1 of 1
    • Remove the back cover after the entire rim is disconnected.
  4. Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: step 4, image 1 of 2 Samsung Galaxy Tab S 8.4 Rear Facing Camera Replacement, Rear Facing Camera: step 4, image 2 of 2
    • Gently pry the camera connector away from the motherboard with a plastic opening tool or your fingers.
    • Lift the rear-facing camera module up and away from the device.
2 other people completed this guide.
Trent Chapman
1,378 Reputation
3 Guides authored
Cal Poly, Team 12-15, Maness Fall 2015 Member of Cal Poly, Team 12-15, Maness Fall 2015
CPSU-MANESS-F15S12G15
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,440
