Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement
  1. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: step 1, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screen: step 1, image 2 of 2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 2, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 2, image 2 of 2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 3, image 1 of 1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 5, image 1 of 1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: step 6, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Screws: step 6, image 2 of 2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 7, image 1 of 3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 7, image 2 of 3 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 7, image 3 of 3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: step 8, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement, Speaker: step 8, image 2 of 2
    • Locate the speakers towards the bottom.
    • For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
  9. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 9, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 9, image 2 of 2
    • Apply the iOpener to the magnet to loosen the adhesive glue.
    • Refer to the iOpener guide for more help.
    • If you do not have access to an iOpener, you may also use a heat gun or a hair dryer.
  10. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 10, image 1 of 1
    Buy
    • Using the precision tweezers, remove the speaker.
  11. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 11, image 1 of 2 Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 11, image 2 of 2
    • For the speaker on the right, use the plastic opening tool to lift up the press-fit connector.
    • Using the precision tweezers, detach the orange cable.
  12. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 12, image 1 of 1
    • Pull the orange ribbon cable out of the ZIF connector using the precision tweezers.
    • Be gentle so that you do not damage the orange ribbon cable.
  13. Samsung Galaxy Tab S2 9.7 AT&T Speaker Replacement: step 13, image 1 of 1
3 other people completed this guide.
Joy Harris
814 Reputation
7 Guides authored
USF Tampa, Team S3-G4, Sullivan Spring 2017 Member of USF Tampa, Team S3-G4, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G4
3 Members
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,259
