Samsung Galaxy Tab S7 Plus Battery Replacement
  1. Samsung Galaxy Tab S7 Plus Battery Replacement, Heat the bottom edge: step 1, image 1 of 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device to loosen the adhesive underneath.
    • The display adhesive of the Galaxy Tab S7+ is extremely strong, and it's likely you need to reheat and reapply the iOpener several times before starting the display removal and during the removal procedure.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  2. Samsung Galaxy Tab S7 Plus Battery Replacement, Screen removal information: step 2, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Screen removal information: step 2, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Screen removal information: step 2, image 3 of 3
    • While you're waiting for the adhesive to loosen, note the following:
    • There's a long circuit board attached to the screen that sits parallel to the bottom edge.
    • Don't insert the pick more than 2 mm to avoid damaging the circuit board.
    • This image shows an example of the display separating from the glass panel.
    • Don't insert the pick more than 3 mm to avoid damaging the display.
  3. Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 3, image 3 of 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction cup to the screen.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  4. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom adhesive: step 4, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom adhesive: step 4, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom adhesive: step 4, image 3 of 3
    • Insert a new opening pick into the gap you created.
    • Slide the new pick along the bottom edge of the device towards the bottom-right corner.
  5. Samsung Galaxy Tab S7 Plus Battery Replacement, Heat the right edge: step 5, image 1 of 1
    • Apply a heated iOpener to the right edge of the device to loosen the adhesive underneath.
  6. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-right corner adhesive: step 6, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-right corner adhesive: step 6, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-right corner adhesive: step 6, image 3 of 3
    • Rotate the opening pick around the bottom-right corner of the device.
  7. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the right adhesive: step 7, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the right adhesive: step 7, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the right adhesive: step 7, image 3 of 3
    • Don't insert the pick more than 3 mm to avoid damaging the components along the right edge.
    • Slide the new pick along the right edge of the device towards the top-right corner.
  8. Samsung Galaxy Tab S7 Plus Battery Replacement, Heat the top edge: step 8, image 1 of 1
    • Apply a heated iOpener to the top edge of the device to loosen the adhesive underneath.
  9. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-right corner adhesive: step 9, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-right corner adhesive: step 9, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-right corner adhesive: step 9, image 3 of 3
    • Rotate the opening pick around the top-right corner of the device.
  10. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top adhesive: step 10, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top adhesive: step 10, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top adhesive: step 10, image 3 of 3
    • Slide the new pick along the top edge of the device towards the top-left corner.
  11. Samsung Galaxy Tab S7 Plus Battery Replacement, Heat the left edge: step 11, image 1 of 1
    • Apply a heated iOpener to the left edge of the device to loosen the adhesive underneath.
  12. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-left corner adhesive: step 12, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-left corner adhesive: step 12, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the top-left corner adhesive: step 12, image 3 of 3
    • Rotate the opening pick around the top-left corner of the device.
  13. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the left adhesive: step 13, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the left adhesive: step 13, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the left adhesive: step 13, image 3 of 3
    • Slide the new pick along the left edge of the device towards the bottom-left corner.
  14. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-left corner adhesive: step 14, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-left corner adhesive: step 14, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the bottom-left corner adhesive: step 14, image 3 of 3
    • Rotate the opening pick around the bottom-left corner of the device.
    • At this point, the perimeter of the screen should be separated from the frame. If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
  15. Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 15, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 15, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 15, image 3 of 3
    Tool used on this step:
    Buy
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the top of the device facing you, pull the screen up and away from you like you're opening a book.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
    • During reassembly:
    • This is a good point to power on your tablet and test all functions before sealing it up. Be sure to power your tablet back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using custom-cut adhesives, follow this guide. If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the display cable: step 16, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the display cable: step 16, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the screen.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Samsung Galaxy Tab S7 Plus Battery Replacement: step 17, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement: step 17, image 2 of 2
    • Use tweezers, or you fingers, to hold the display cable in place.
    • Use the flat end of a spudger to pry up and disconnect the fingerprint sensor's press connector attached to the display cable.
    • Take note of the display cable's position; you will need to bend it in the same way when connecting a new screen.
  18. Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 18, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 18, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the screen: step 18, image 3 of 3
    • Remove the screen from the frame.
  19. Samsung Galaxy Tab S7 Plus Battery Replacement, Unfasten the frame bracket: step 19, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Unfasten the frame bracket: step 19, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Unfasten the frame bracket: step 19, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the fifty 3 mm-long screws securing the frame bracket to the frame.
    • The third photo has the same screws marked by quadrant. Use this photo during reassembly to help account for all the screws:
    • Bottom left = 9 screws
    • Bottom right = 14 screws
    • Top right = 12 screws
    • Top left = 15 screws
  20. Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the frame bracket: step 20, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the frame bracket: step 20, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the frame bracket: step 20, image 3 of 3
    • Lift the frame bracket away from the frame, making sure to thread the display cable through its socket.
  21. Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the battery: step 21, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the battery: step 21, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the battery's press connector secured to the motherboard.
  22. Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the display cable: step 22, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the display cable: step 22, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the display cable: step 22, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's press connector secured to the motherboard.
    • Repeat for the fingerprint sensor cable attached to display cable.
  23. Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the display cable: step 23, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the display cable: step 23, image 2 of 2
    • Use your fingers to remove the display cable.
  24. Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the keyboard dock port cable: step 24, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the keyboard dock port cable: step 24, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the keyboard dock port cable's press connector secured to the motherboard.
  25. Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the daughterboard interconnect cable: step 25, image 1 of 2 Samsung Galaxy Tab S7 Plus Battery Replacement, Disconnect the daughterboard interconnect cable: step 25, image 2 of 2
    • Use the flat end of a spudger to pry up and disconnect the daughterboard interconnect cable's press connector secured to the motherboard.
  26. Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the keyboard dock port cable: step 26, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the keyboard dock port cable: step 26, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the keyboard dock port cable: step 26, image 3 of 3
    Buy
    • Use blunt tweezers, or your fingers, to bend the orange keyboard dock port cable away from the device.
    • Avoid folding or sharply bending the cable while repositioning it; doing so could tear the cable.
  27. Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the interconnect cable: step 27, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the interconnect cable: step 27, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Reposition the interconnect cable: step 27, image 3 of 3
    • Use blunt tweezers, or your fingers, to bend the interconnect cable away from the device.
  28. Samsung Galaxy Tab S7 Plus Battery Replacement, Apply isopropyl alcohol: step 28, image 1 of 1
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire. In case you're struggling to pull up the battery, apply more isopropyl alcohol and try again.
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's right edge.
    • Wait between one to two minutes for the adhesive to loosen.
    • Only apply a few drops initially and apply more if necessary; too much isopropyl alcohol might overflow onto the motherboard and daughterboard.
  29. Samsung Galaxy Tab S7 Plus Battery Replacement, Battery removal information: step 29, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Battery removal information: step 29, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Battery removal information: step 29, image 3 of 3
    • The battery is comprised of two cells that are shrouded in a plastic jacket.
    • The adhesive securing the battery to the frame is concentrated in a ring shape around the perimeter of the battery.
    • To minimize the risk of bending or breaking the cells, it's recommended you separate the adhesive cell-by-cell before the entire battery is removed.
  30. Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 30, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 30, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 30, image 3 of 3
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Insert an opening pick into the edge with the widest gap between the frame and the battery.
  31. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 31, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 31, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 31, image 3 of 3
    • Rotate the opening pick to insert its long edge into the gap.
    • Pull up on the suction cup with strong, steady force and pry up with the opening pick to separate the battery from the frame.
    • Create an opening wide enough for a plastic card to be inserted; you will be unable to fully separate the battery's adhesive with the pick.
  32. Samsung Galaxy Tab S7 Plus Battery Replacement: step 32, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement: step 32, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement: step 32, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • Insert a plastic card into the gap between the frame and the battery.
    • Use the plastic card to slice the adhesive underneath the battery.
  33. Samsung Galaxy Tab S7 Plus Battery Replacement, Create a gap between the battery and frame: step 33, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Create a gap between the battery and frame: step 33, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Create a gap between the battery and frame: step 33, image 3 of 3
    • Insert an opening pick into the edge with the widest gap between the frame and the battery's left edge.
    • Slide the pick along the battery's edge to create a gap wide enough for isopropyl alcohol to be added.
  34. Samsung Galaxy Tab S7 Plus Battery Replacement, Apply isopropyl alcohol: step 34, image 1 of 1
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's left edge.
  35. Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 35, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 35, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Insert an opening pick: step 35, image 3 of 3
    • Apply a suction cup to the battery, as close to the center of the left edge as possible.
  36. Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 36, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 36, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Separate the battery's adhesive: step 36, image 3 of 3
  37. Samsung Galaxy Tab S7 Plus Battery Replacement: step 37, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement: step 37, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement: step 37, image 3 of 3
  38. Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the battery: step 38, image 1 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the battery: step 38, image 2 of 3 Samsung Galaxy Tab S7 Plus Battery Replacement, Remove the battery: step 38, image 3 of 3
    • If there's any resistance when removing the battery, use a plastic card to slice around the battery's edges again.
    • Remove the battery.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it off or allow it to dry before installing a new battery.
    • During reassembly, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy Tab S7+ Answers community for help.
2 other people completed this guide.
Alex Diaz-Kokaisl
162,005 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,413 Guides authored
7 Comments
Where do we just get the battery for the Tab S7 Plus
Bryan Gutierrez - Reply
Holy cow. Who would dare attempt this?
Foos Research - Reply
Seriously, no one! LOL
Andrea Starr -
This question is probably dumb but is the sheer heat from the IOpener able to crack the screen?
Bernardo Simões de Abreu - Reply
Well I don't know about anybody else but I'm absolutely cacking it. ($@$*!&%& myself)
My galaxy Tab S7 plus just literally stop charging I've tried multiple new cables magnetic cables nothing works it won't charge now and it's 0% so I have no choice but to attempt this.
I wonder how much extra would cost if I took this to a shop and got them to repair it for me.
Bear in mind I spent about 800 quid on the tablet.
I mean they've covered every step beautifully, what can go wrong? Lol
Would have been creatively added a video tutorial.
Rukaslyricist X - Reply
Past 24 Hours: 16
Past 7 Days: 70
Past 30 Days: 285
All Time: 15,088
