Samsung Galaxy Watch Active2 Battery Replacement
Tobias Isakeit
Tobias Isakeit and one other contributor
Last updated on June 17, 2024
40 minutes - 1 hour
Moderate
Featured Guide
Introduction
Go to step 1
Use this guide to replace a worn-out or dead battery in your Samsung Galaxy Watch Active2.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your watch. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You might need replacement adhesive to reattach the battery when reassembling the device.
Parts
Tools
Show more…
  1. Samsung Galaxy Watch Active2 Battery Replacement, Turn off the watch: step 1, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Turn off the watch: step 1, image 2 of 2
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Battery Replacement, Remove the rear screws: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: step 3, image 1 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: step 3, image 2 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Separate the back cover from the housing: step 3, image 3 of 3
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the sensor array: step 4, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the sensor array: step 4, image 2 of 2
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Battery Replacement, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: step 6, image 1 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: step 6, image 2 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the display and speaker: step 6, image 3 of 3
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 1 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 2 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Disconnect the barometric sensor, buttons, and mic: step 7, image 3 of 3
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Battery Replacement, Lift the core assembly: step 8, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Lift the core assembly: step 8, image 2 of 2
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: step 9, image 1 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: step 9, image 2 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Remove the core assembly: step 9, image 3 of 3
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Battery Replacement, Flip the Core Assembly: step 10, image 1 of 1
    • Flip the core assembly over so the motherboard faces down.
  11. Samsung Galaxy Watch Active2 Battery Replacement, Undo the top button: step 11, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Undo the top button: step 11, image 2 of 2
    • Use the tip of an opening pick to peel the top button off the plastic frame.
  12. Samsung Galaxy Watch Active2 Battery Replacement, Remove the motherboard screw: step 12, image 1 of 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw holding the motherboard in place.
  13. Samsung Galaxy Watch Active2 Battery Replacement, Free the motherboard: step 13, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Free the motherboard: step 13, image 2 of 2
    • Place the flat end of a spudger between the motherboard and the plastic frame near the copper coil at the bottom right.
    • Twist the spudger to free the motherboard from the plastic tabs.
  14. Samsung Galaxy Watch Active2 Battery Replacement, Remove the motherboard: step 14, image 1 of 1
    • Slide the motherboard out from under the remaining plastic tabs to remove it.
  15. Samsung Galaxy Watch Active2 Battery Replacement, Lift the battery: step 15, image 1 of 2 Samsung Galaxy Watch Active2 Battery Replacement, Lift the battery: step 15, image 2 of 2
    • Insert the flat end of a spudger between the bottom of the battery and the core frame.
    • The battery is secured with some mild adhesive. If the adhesive is too strong you can use a hair dryer to soften it.
    • Use the spudger to lever up the battery.
    • Take care not to puncture or bend the battery. Only use plastic tools. A punctured or bent battery may leak dangerous chemicals or cause a thermal event.
  16. Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: step 16, image 1 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: step 16, image 2 of 3 Samsung Galaxy Watch Active2 Battery Replacement, Remove the battery: step 16, image 3 of 3
    Tool used on this step:
    • Use a pair of tweezers to grab the connector and slowly pull it off the core frame.
    • The battery connector is affixed with mild adhesive.
    • Remove the battery from the core assembly.
    • When installing a new battery make sure the tiny hole on the battery connector aligns with the pin on the core frame.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. Press the new battery firmly into place.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 1 more hour. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
32 other people completed this guide.
Tobias Isakeit
123,979 Reputation
189 Guides authored
18 Comments
Hi. How can I distinguish between battery rather than motherboard disfunción? My watch doesn't charge anymore. It appears to start charging but doesn't.
Dan Frank - Reply
It doesn't appear swollen either. Took to the beach and swam on salty water and pool… didn't work after.
Dan Frank -
This is the SAME thing that is happening to me. Went to the beach, on the drive home it died, hasn’t charged since. I set it on the charger and it will say 0%, but never charge enough to power on. I took to best buy and they said I need to buy a new watch :(. Would also like to know if you think it is the battery or if the beach water could have fried the whole thing. I wouldn’t think it would since it occasionally will flash the 0% when try to charge it.
Branddy Hopkins - Reply
Exact same thing in two separate cases. That's it. 0% flashing sometimes and completely dead. And as it seems nobody but us is posting our sad stories. We need to look further and find something on YouTube or online… there must be something…
Dan Frank -
I have been looking online and it seems that the battery has lower charge than what is chargeable. And by going deeper it also seems that there is a way to recharge that same battery at least to the point we're it might start again.
Dan Frank -
Past 24 Hours: 18
Past 7 Days: 182
Past 30 Days: 635
All Time: 64,731
