Samsung Galaxy Watch Display Replacement
  1. Samsung Galaxy Watch Display Replacement, Opening Procedure: step 1, image 1 of 1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Samsung Galaxy Watch Display Replacement: step 2, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 2, image 2 of 2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Samsung Galaxy Watch Display Replacement: step 3, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 3, image 2 of 2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Samsung Galaxy Watch Display Replacement: step 4, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 4, image 2 of 2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch Display Replacement: step 5, image 1 of 3 Samsung Galaxy Watch Display Replacement: step 5, image 2 of 3 Samsung Galaxy Watch Display Replacement: step 5, image 3 of 3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
  6. Samsung Galaxy Watch Display Replacement, Core Assembly Removal: step 6, image 1 of 2 Samsung Galaxy Watch Display Replacement, Core Assembly Removal: step 6, image 2 of 2
    • Use a spudger to disconnect the display flex cable from the motherboard.
  7. Samsung Galaxy Watch Display Replacement: step 7, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 7, image 2 of 2
    • Lift the core unit out of the housing.
    • The core's plastic frame sits tight inside the housing.
    • Carefully thread the display flex cable through the gap of the core's plastic frame.
  8. Samsung Galaxy Watch Display Replacement, Display: step 8, image 1 of 1
    • If necessary apply some tape over the display to avoid any injury from glass shards.
  9. Samsung Galaxy Watch Display Replacement: step 9, image 1 of 2 Samsung Galaxy Watch Display Replacement: step 9, image 2 of 2
    • Use your finger or thumb to steadily push down on the display to loosen the adhesive.
    • Heating the display with a hair dryer or iOpener helps softening the adhesive.
    • Remove the display.
8 other people completed this guide.
Tobias Isakeit
119,540 Reputation
189 Guides authored
One Comment
Hi does this process work with the galaxy 5 watch?
Rey Thomas Jude Ho - Reply
Past 24 Hours: 60
Past 7 Days: 423
Past 30 Days: 1,528
All Time: 55,797
