Samsung Galaxy Watch4 Classic Motherboard Replacement
  1. Samsung Galaxy Watch4 Classic Motherboard Replacement, Power down your watch: step 1, image 1 of 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Samsung Galaxy Watch4 Classic Motherboard Replacement, Unscrew the back cover: step 2, image 1 of 1
    • Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
  3. Samsung Galaxy Watch4 Classic Motherboard Replacement, Pry open the back cover: step 3, image 1 of 2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Pry open the back cover: step 3, image 2 of 2
    • Insert an opening tool into the seam between the back cover and the metal housing.
    • Twist the opening tool to create a gap.
    • Don't try to remove the back cover all the way yet. The sensor flex cable is still connected to the motherboard.
  4. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the sensor flex cable: step 4, image 1 of 2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the sensor flex cable: step 4, image 2 of 2
    • Lay the watch face down.
    • Carefully swing open the back cover by folding it to the opposite site of the created gap.
    • Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
  5. Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the back cover: step 5, image 1 of 1
    • Remove the back cover.
    • Make sure the rubber gasket is undamaged. If damaged, replace it with a new one during reassembly to maintain proper water resistance.
  6. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the hall sensor flex cable: step 6, image 1 of 2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the hall sensor flex cable: step 6, image 2 of 2
    • Use the pointed end of a spudger to disconnect the hall sensor flex cable.
  7. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the display flex cable: step 7, image 1 of 2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the display flex cable: step 7, image 2 of 2
    • Use a spudger to disconnect the display flex cable.
  8. Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the side buttons: step 8, image 1 of 2 Samsung Galaxy Watch4 Classic Motherboard Replacement, Disconnect the side buttons: step 8, image 2 of 2
    • Use a spudger to disconnect the crown button flex cable.
  9. Samsung Galaxy Watch4 Classic Motherboard Replacement, Unscrew the motherboard: step 9, image 1 of 1
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw securing the motherboard.
  10. Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: step 10, image 1 of 3 Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: step 10, image 2 of 3 Samsung Galaxy Watch4 Classic Motherboard Replacement, Remove the motherboard: step 10, image 3 of 3
    • Use your fingers to lift the motherboard out from the watch assembly towards the bottom of the watch.
    • During reassembly, make sure none of the flex cables become trapped underneath the motherbaord.
If possible, turn on your device and test your repair before resealing.
Adriana Zwink
48,810 Reputation
167 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 9
Past 30 Days: 37
All Time: 1,467
