Samsung Gear 360 Rear Camera Replacement
  1. Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 1 of 3 Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 2 of 3 Samsung Gear 360 Rear Camera Replacement, Case: step 1, image 3 of 3
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Rear Camera Replacement: step 2, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 2, image 2 of 2
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Rear Camera Replacement: step 3, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 3, image 2 of 2
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Rear Camera Replacement: step 4, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 4, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 4, image 3 of 3
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Rear Camera Replacement: step 5, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 5, image 2 of 2
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Rear Camera Replacement: step 6, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 6, image 2 of 2
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Rear Camera Replacement: step 7, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 7, image 2 of 2
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Rear Camera Replacement: step 8, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 8, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 8, image 3 of 3
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Rear Camera Replacement: step 9, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 9, image 2 of 2
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Rear Camera Replacement: step 10, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 10, image 2 of 2
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Rear Camera Replacement: step 11, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 11, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 11, image 3 of 3
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Rear Camera Replacement: step 12, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 12, image 2 of 2
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Rear Camera Replacement: step 13, image 1 of 3 Samsung Gear 360 Rear Camera Replacement: step 13, image 2 of 3 Samsung Gear 360 Rear Camera Replacement: step 13, image 3 of 3
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Rear Camera Replacement, Rear Camera: step 14, image 1 of 2 Samsung Gear 360 Rear Camera Replacement, Rear Camera: step 14, image 2 of 2
    • Within the grey half of the case, unscrew both Phillips #00 0.75 mm screws located on the metal plate using PH00 screwdriver.
  15. Samsung Gear 360 Rear Camera Replacement: step 15, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 15, image 2 of 2
    • Once the screws have been removed, remove the metal plate.
  16. Samsung Gear 360 Rear Camera Replacement: step 16, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 16, image 2 of 2
    • Using a PH000 screwdriver head, remove the both Phillips #000 0.75 mm screws on the grey case.
  17. Samsung Gear 360 Rear Camera Replacement: step 17, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 17, image 2 of 2
    • Using a plastic opening tool, remove the plastic cover underneath the rear camera
  18. Samsung Gear 360 Rear Camera Replacement: step 18, image 1 of 2 Samsung Gear 360 Rear Camera Replacement: step 18, image 2 of 2
    • Gently remove the rear camera module by using a plastic opening tool and lifting the module.
2 other people completed this guide.
Connor
454 Reputation
3 Guides authored
USF Tampa, Team S3-G5, Sullivan Spring 2017 Member of USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Members
14 Guides authored
One Comment
number datasheet sensor camera?
Pelicula 360 - Reply
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 1,369
