Samsung Gear Live Watchband Replacement
  1. Samsung Gear Live Watchband Replacement, Lay the watch face-down: step 1, image 1 of 1
    • Lay the watch face-down on a flat, stable surface.
  2. Samsung Gear Live Watchband Replacement, Remove the holding pin: step 2, image 1 of 1
    • Press the watchband down against the work surface.
    • Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
  3. Samsung Gear Live Watchband Replacement, Remove the watchband: step 3, image 1 of 1
    • With the spring-loaded pin pressed in, the watch band should release easily.
    • Gently pull the band away from the body of the watch.
    • Repeat steps 2 and 3 for the opposite side.
2 other people completed this guide.
Keith Cooper
1,241 Reputation
6 Guides authored
USF Tampa, Team 1-7, Brown Fall 2014 Member of USF Tampa, Team 1-7, Brown Fall 2014
USFT-BROWN-F14S1G7
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 1,641
