Samsung Gear S Display Assembly Replacement
  1. Samsung Gear S Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 Samsung Gear S Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 Samsung Gear S Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
  2. Samsung Gear S Display Assembly Replacement: step 2, image 1 of 2 Samsung Gear S Display Assembly Replacement: step 2, image 2 of 2
    • Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
    • Some force is needed due to adhesive seal.
  3. Samsung Gear S Display Assembly Replacement: step 3, image 1 of 1
    • Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
  4. Samsung Gear S Display Assembly Replacement: step 4, image 1 of 1
    • Locate the ribbon assembly attaching the display to the motherboard.
  5. Samsung Gear S Display Assembly Replacement: step 5, image 1 of 1
    • Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
  6. Samsung Gear S Display Assembly Replacement: step 6, image 1 of 1
    • Now the watch should be in three separate pieces.
To reassemble your device, follow these instructions in reverse order. You will need an adhesive to connect the screen back to the rest of the watch.
19 other people completed this guide.
Crystal Schmitt
679 Reputation
1 Guide authored
USF Tampa, Team 12-1, Blackwell Fall 2015 Member of USF Tampa, Team 12-1, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G1
4 Members
5 Guides authored
16 Comments
Where can i get the LCD for Gear S
Kuek See Chuan - Reply
my screen flashing light and show on screen lines
avi mor - Reply
Hi my gear is showing the watch face setting then glitches to the photo setting and is not allowing me to use any other apps?
Mark Measures - Reply
My watch is doing the same thing. Did you get a fix for it?
steve Walks -
There are flashing yellow lights on the screen, could I fix that?
Alex - Reply
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 17
All Time: 15,500
