Samsung Gear S2 Back Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Samsung Gear S2 Back Replacement, Watch Strap: step 1, image 1 of 2 Samsung Gear S2 Back Replacement, Watch Strap: step 1, image 2 of 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Back Replacement: step 2, image 1 of 2 Samsung Gear S2 Back Replacement: step 2, image 2 of 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Back Replacement: step 3, image 1 of 2 Samsung Gear S2 Back Replacement: step 3, image 2 of 2
    • Repeat the procedure from step 2 for the other strap.
  4. Samsung Gear S2 Back Replacement, Back: step 4, image 1 of 2 Samsung Gear S2 Back Replacement, Back: step 4, image 2 of 2
    • Insert a plastic opening tool between the top and bottom portions of the case, and gently pry off the back.
    • Do not insert the tool more than 3 millimeters into the case. Inserting more than 3 mm may damage the seal and electric components.
Jacob Baldwin
3,412 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Sullivan Spring 2017 Member of USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Members
23 Guides authored
One Comment
And where do you get the new replacement back? And does it just snap back on?
shawntravis76 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 416
