Samsung Gear S2 Watch Strap Replacement
  1. Samsung Gear S2 Watch Strap Replacement, Watch Strap: step 1, image 1 of 2 Samsung Gear S2 Watch Strap Replacement, Watch Strap: step 1, image 2 of 2
    • Flip the watch over so that the face is down.
    • Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
    • Remember to turn off the watch to avoid being shocked.
  2. Samsung Gear S2 Watch Strap Replacement: step 2, image 1 of 2 Samsung Gear S2 Watch Strap Replacement: step 2, image 2 of 2
    • Using your finger, push forward on the release while pulling up on the strap.
    • You may find it helpful to use the flat end of a spudger to push on the release instead of your finger.
  3. Samsung Gear S2 Watch Strap Replacement: step 3, image 1 of 2 Samsung Gear S2 Watch Strap Replacement: step 3, image 2 of 2
    • Repeat the procedure from step 2 for the other strap.
7 other people completed this guide.
Jacob Baldwin
3,412 Reputation
5 Guides authored
USF Tampa, Team S2-G3, Sullivan Spring 2017 Member of USF Tampa, Team S2-G3, Sullivan Spring 2017
USFT-SULLIVAN-S17S2G3
3 Members
23 Guides authored
6 Comments
can you also provide instruction to change home button on Gear S2
thanks
inder kapoor - Reply
you have to buy the continuing transfunctioner to change the home button on the gear s2
i have some for sale if interested
bobby - Reply
Where can you buy new straps?
Olga Andreu - Reply
Ebay Amazon etc.
Jens Troemer - Reply
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
Ryo Kimball - Reply
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 65
All Time: 9,480
