Samsung Gear S3 Frontier Front Screen Assembly Replacement
Jimmy Algeo
Jimmy Algeo and 3 other contributors
Last updated on June 18, 2020
10 - 45 minutes
Moderate
Introduction
Go to step 1
If your device's touchscreen is unresponsive or cracked, replace it with this guide. This will require you to replace the whole front screen assembly, as you can't just replace the screen itself.
Tools
Show more…
  1. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Back Cover: step 1, image 1 of 1
    • Place the watch screen-down so that its back cover is showing.
  2. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 2, image 1 of 2 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 2, image 2 of 2
    • Remove the four 4.2mm screws with a Y00 screwdriver.
  3. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 3, image 3 of 3
    • This step will ruin the water-proof seal.
    • Wedge the metal spudger in between the back cover and the frame along the seam.
    • Use force to pry the back cover away from the main watch frame.
    • This step requires a lot of force. You can use a Jimmy in place of a metal spudger to make the process easier.
  4. Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement, Front Screen Assembly: step 4, image 3 of 3
    • Detach the three connectors on the motherboard using your fingernail.
    • The connectors are easy to pop off. Minimal force is necessary.
  5. Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 1 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 2 of 3 Samsung Gear S3 Frontier Front Screen Assembly Replacement: step 5, image 3 of 3
    • Separate the motherboard and front screen assembly using a spudger.
14 other people completed this guide.
Jimmy Algeo
870 Reputation
2 Guides authored
Cal Poly, Team S15-G2, White Fall 2018 Member of Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Members
34 Guides authored
9 Comments
can you tell me where can i buy the whole front screen  ?
Ahmad Hariki - Reply
Jerzy Jerzyk - Reply
Same question, I am having great difficulty in locating the PARTS to complete these repairs. Can someone please list where we can actually purchase the replacement parts that are shown in these guides??
ArcadeDude44 - Reply
Can anyone please tell, where to get the parts?
Sunny Tate - Reply
Eleazar Lagundino - Reply
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 64
All Time: 21,221
