Samsung Gear S3 Frontier Wristband  Replacement
Corey Rumbaugh
Corey Rumbaugh and 3 other contributors
Last updated on September 30, 2020
1 - 5 minutes
Very easy
Introduction
Go to step 1
Is your wristband damaged or do you want to change it for a new one? If so, follow this this replacement guide to learn how to do so.
Video Overview
  1. Samsung Gear S3 Frontier Wristband  Replacement, Wristband: step 1, image 1 of 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: step 1, image 2 of 3 Samsung Gear S3 Frontier Wristband  Replacement, Wristband: step 1, image 3 of 3
    • Place the watch screen-down so that its back cover is showing.
    • Use your nail to push the small silver ball bearing on the right side downward.
    • If your nails aren't sharp enough, you can use a sharp pointed object such as a toothpick or pen.
    • While the ball is pressed down, pull the wristband outwards until the strap is disconnected from the main frame.
    • For reassembly, hold the ball down and then wedge each pin on the wristband into the pin holes of the main frame.
    • Follow the same steps for the ball on the left side, except this time push the ball upwards and then pull outwards.
2 other people completed this guide.
Corey Rumbaugh
1,555 Reputation
1 Guide authored
Cal Poly, Team S15-G2, White Fall 2018 Member of Cal Poly, Team S15-G2, White Fall 2018
CPSU-WHITE-F18S15G2
4 Members
34 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 59
All Time: 3,007
