Samsung Gear VR Front Phone Mount Replacement
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: step 1, image 1 of 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: step 1, image 2 of 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: step 1, image 3 of 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: step 2, image 1 of 2 Samsung Gear VR Front Phone Mount Replacement: step 2, image 2 of 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
Garrett Moncrief
179 Reputation
1 Guide authored
USF Tampa, Team S4-G6, Eyestone Fall 2017 Member of USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 19
All Time: 1,253
