Samsung Gear VR Trackpad Replacement
  1. Samsung Gear VR Trackpad Replacement, Front Phone Mount: step 1, image 1 of 3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: step 1, image 2 of 3 Samsung Gear VR Trackpad Replacement, Front Phone Mount: step 1, image 3 of 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Trackpad Replacement: step 2, image 1 of 2 Samsung Gear VR Trackpad Replacement: step 2, image 2 of 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Trackpad Replacement, Motherboard: step 3, image 1 of 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Trackpad Replacement: step 4, image 1 of 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Trackpad Replacement, Inner Mask: step 5, image 1 of 3 Samsung Gear VR Trackpad Replacement, Inner Mask: step 5, image 2 of 3 Samsung Gear VR Trackpad Replacement, Inner Mask: step 5, image 3 of 3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
  6. Samsung Gear VR Trackpad Replacement, Trackpad: step 6, image 1 of 2 Samsung Gear VR Trackpad Replacement, Trackpad: step 6, image 2 of 2
    • Pry the trackpad sensor loose from the mask.
    • I found that prying the metal spudger underneath the small outcropping at the bottom of the sensor to be the easiest way to remove the piece.
Alfredo Aparicio
325 Reputation
3 Guides authored
USF Tampa, Team S4-G6, Eyestone Fall 2017 Member of USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 1,261
