Samsung Glyde Motherboard Replacement
  1. Samsung Glyde Motherboard Replacement, Battery: step 1, image 1 of 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Motherboard Replacement: step 2, image 1 of 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Motherboard Replacement, Motherboard: step 3, image 1 of 2 Samsung Glyde Motherboard Replacement, Motherboard: step 3, image 2 of 2
    • Using a Phillips#00 screw driver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Motherboard Replacement: step 4, image 1 of 2 Samsung Glyde Motherboard Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Motherboard Replacement: step 5, image 1 of 2 Samsung Glyde Motherboard Replacement: step 5, image 2 of 2
    • The green film above the camera is the camera connector to the motherboard.
    • Use a plastic opening tool to disconnect the camera connector.
  6. Samsung Glyde Motherboard Replacement: step 6, image 1 of 2 Samsung Glyde Motherboard Replacement: step 6, image 2 of 2
    • The golden film connector connects the keyboard to the motherboard.
    • Use a plastic opening tool to disconnect the keyboard connector.
  7. Samsung Glyde Motherboard Replacement: step 7, image 1 of 2 Samsung Glyde Motherboard Replacement: step 7, image 2 of 2
    • The circular connector holds the motherboard in place.
    • Using a plastic opening tool, disconnect the circular connector.
  8. Samsung Glyde Motherboard Replacement: step 8, image 1 of 3 Samsung Glyde Motherboard Replacement: step 8, image 2 of 3 Samsung Glyde Motherboard Replacement: step 8, image 3 of 3
    • There is a LCD connector underneath the motherboard.
    • Gently lift the far edge of the motherboard upwards toward the center of the phone.
    • Using a plastic opening tool, disconnect the LCD connector.
  9. Samsung Glyde Motherboard Replacement: step 9, image 1 of 2 Samsung Glyde Motherboard Replacement: step 9, image 2 of 2
    • After disconnecting the four connectors, gently lift the motherboard up with your fingers.
    • Place the motherboard in a secure area.
Stephen
26 Reputation
1 Guide authored
Cal Poly, Team 3-12, Regan Fall 2011 Member of Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,121
