Samsung HD Pro Motherboard Replacement
  1. Samsung HD Pro Motherboard Replacement, Casing: step 1, image 1 of 1
    • Locate a small opening around the front panel of the camera.
  2. Samsung HD Pro Motherboard Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, apply pressure to various points around the camera to pry open the front panel.
  3. Samsung HD Pro Motherboard Replacement: step 3, image 1 of 1
    • Remove both of the connecting wires from the motherboard.
    • Be careful to not bend headers or damage the wires.
  4. Samsung HD Pro Motherboard Replacement: step 4, image 1 of 1
    • Apply a plastic opening tool to the gray plastic band around the case of the camera. Insert the edge of the spudger between the case of the camera and the gray plastic band.
  5. Samsung HD Pro Motherboard Replacement: step 5, image 1 of 1
    • Apply pressure with the plastic opening tool to various areas of the gray plastic band to pry it from the white plastic back of the case.
  6. Samsung HD Pro Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Check to make sure all wires are completely detached from the motherboard.
  7. Samsung HD Pro Motherboard Replacement: step 7, image 1 of 1
    • Pull the circular circuit board away from the rest of the device, being careful not to bend any of the pins connecting the two.
  8. Samsung HD Pro Motherboard Replacement: step 8, image 1 of 1
    • Locate the three white tabs holding the next circuit board inside the case.
  9. Samsung HD Pro Motherboard Replacement: step 9, image 1 of 1
    • Press each tab while using a plastic opening tool to pry the motherboard up in the location near the tab.
  10. Samsung HD Pro Motherboard Replacement: step 10, image 1 of 1
    • Unplug the final group of wires from the bottom of the second circuit board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 582
