Samsung HMX-F90 Lens Replacement
  1. Samsung HMX-F90 Lens Replacement, Battery: step 1, image 1 of 3 Samsung HMX-F90 Lens Replacement, Battery: step 1, image 2 of 3 Samsung HMX-F90 Lens Replacement, Battery: step 1, image 3 of 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: step 2, image 1 of 2 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: step 2, image 2 of 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: step 3, image 1 of 2 Samsung HMX-F90 Lens Replacement: step 3, image 2 of 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: step 4, image 1 of 2 Samsung HMX-F90 Lens Replacement: step 4, image 2 of 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: step 5, image 1 of 3 Samsung HMX-F90 Lens Replacement: step 5, image 2 of 3 Samsung HMX-F90 Lens Replacement: step 5, image 3 of 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: step 6, image 1 of 2 Samsung HMX-F90 Lens Replacement, Lens: step 6, image 2 of 2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: step 7, image 1 of 2 Samsung HMX-F90 Lens Replacement: step 7, image 2 of 2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: step 8, image 1 of 2 Samsung HMX-F90 Lens Replacement: step 8, image 2 of 2
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: step 9, image 1 of 3 Samsung HMX-F90 Lens Replacement: step 9, image 2 of 3 Samsung HMX-F90 Lens Replacement: step 9, image 3 of 3
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: step 10, image 1 of 3 Samsung HMX-F90 Lens Replacement: step 10, image 2 of 3 Samsung HMX-F90 Lens Replacement: step 10, image 3 of 3
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
3 other people completed this guide.
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 30
All Time: 1,226
