Samsung HMX-F90 Record Button Replacement
  1. Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 1 of 3 Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 2 of 3 Samsung HMX-F90 Record Button Replacement, Battery: step 1, image 3 of 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: step 2, image 1 of 2 Samsung HMX-F90 Record Button Replacement, Strap Side Outer Casing: step 2, image 2 of 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Record Button Replacement: step 3, image 1 of 2 Samsung HMX-F90 Record Button Replacement: step 3, image 2 of 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Record Button Replacement: step 4, image 1 of 2 Samsung HMX-F90 Record Button Replacement: step 4, image 2 of 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Record Button Replacement: step 5, image 1 of 3 Samsung HMX-F90 Record Button Replacement: step 5, image 2 of 3 Samsung HMX-F90 Record Button Replacement: step 5, image 3 of 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 1 of 3 Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 2 of 3 Samsung HMX-F90 Record Button Replacement, Record Button: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Locate plastic clips of the record button.
    • With tweezers squeeze together the two plastic clips and push the button out.
    • Wiggle and pull the record button to remove completely.
Amir Harb
705 Reputation
6 Guides authored
USF Tampa, Team S13-G1, Boczar Fall 2017 Member of USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 303
