Samsung HMX-QF20 Lens Cover Replacement
  1. Samsung HMX-QF20 Lens Cover Replacement, Lens: step 1, image 1 of 1
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Lens Cover Replacement: step 2, image 1 of 1
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Lens Cover Replacement: step 3, image 1 of 1
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Lens Cover Replacement: step 4, image 1 of 1
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Lens Cover Replacement: step 5, image 1 of 1
    • Remove the three 5 mm screws surrounding the lens.
Renee
219 Reputation
2 Guides authored
Marist, Team 1-5, Laflen Spring 2015 Member of Marist, Team 1-5, Laflen Spring 2015
MARS-LAFLEN-S15S1G5
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 303
