Samsung Impression Back Speaker Replacement
  1. Samsung Impression Back Speaker Replacement, Battery: step 1, image 1 of 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Back Speaker Replacement: step 2, image 1 of 2 Samsung Impression Back Speaker Replacement: step 2, image 2 of 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Back Speaker Replacement, Back Cover: step 3, image 1 of 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Back Speaker Replacement: step 4, image 1 of 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Back Speaker Replacement, Back Speaker: step 5, image 1 of 1
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
3 other people completed this guide.
Ross McKelvie
196 Reputation
4 Guides authored
Cal Poly, Team 8-10, Regan Spring 2011 Member of Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Members
23 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 36
All Time: 2,270
