Introduction
How to remove & replace the phone's back camera.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
Turn the circuit board over.
The bottom of the camera will have a gold ribbon coming out of it which attaches to the circuit board.
Pull upwards on the blue rectangle where the gold ribbon ends. This will remove the camera from the circuit board.
