Introduction
Disassembling the stovetop will follow the same process that is documented in the guide replacing the right power inverter. This guide assumes you have the stove disassembled.
Disconnect all the cables from the board.
Remove the screws from the board
There are two plastic pins that hold the board. Use a pair of pliers to squeeze the pin straight and lift the board out.
Almost done!
