Samsung Instinct Back Case Replacement
  1. Samsung Instinct Back Case Replacement, Battery: step 1, image 1 of 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Back Case Replacement: step 2, image 1 of 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Back Case Replacement, Back Case: step 3, image 1 of 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Back Case Replacement: step 4, image 1 of 2 Samsung Instinct Back Case Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Back Case Replacement: step 5, image 1 of 1
    • Lift the casing off of the phone.
Jacob Michener
31 Reputation
2 Guides authored
Cal Poly, Team 3-13, Regan Fall 2011 Member of Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 965
