Samsung Instinct Motherboard Replacement
  1. Samsung Instinct Motherboard Replacement, Battery: step 1, image 1 of 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Motherboard Replacement: step 2, image 1 of 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Motherboard Replacement, Back Case: step 3, image 1 of 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Motherboard Replacement: step 4, image 1 of 2 Samsung Instinct Motherboard Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Motherboard Replacement: step 5, image 1 of 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Motherboard Replacement, Antenna: step 6, image 1 of 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Motherboard Replacement: step 7, image 1 of 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Motherboard Replacement: step 8, image 1 of 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Motherboard Replacement: step 9, image 1 of 1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Motherboard Replacement, Front Case: step 10, image 1 of 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Motherboard Replacement: step 11, image 1 of 3 Samsung Instinct Motherboard Replacement: step 11, image 2 of 3 Samsung Instinct Motherboard Replacement: step 11, image 3 of 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Motherboard Replacement: step 12, image 1 of 1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Motherboard Replacement: step 13, image 1 of 2 Samsung Instinct Motherboard Replacement: step 13, image 2 of 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Motherboard Replacement: step 14, image 1 of 1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Motherboard Replacement: step 15, image 1 of 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Motherboard Replacement, Motherboard: step 16, image 1 of 3 Samsung Instinct Motherboard Replacement, Motherboard: step 16, image 2 of 3 Samsung Instinct Motherboard Replacement, Motherboard: step 16, image 3 of 3
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
  17. Samsung Instinct Motherboard Replacement: step 17, image 1 of 1
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
  18. Samsung Instinct Motherboard Replacement: step 18, image 1 of 1
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
  19. Samsung Instinct Motherboard Replacement: step 19, image 1 of 1
    • Gently lift the motherboard from the center frame.
Brayton
49 Reputation
2 Guides authored
Cal Poly, Team 3-13, Regan Fall 2011 Member of Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 5,238
