Samsung Jack Keyboard Replacement
  1. Samsung Jack Keyboard Replacement, Battery: step 1, image 1 of 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Keyboard Replacement: step 2, image 1 of 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Keyboard Replacement, Rear Case: step 3, image 1 of 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Keyboard Replacement: step 4, image 1 of 3 Samsung Jack Keyboard Replacement: step 4, image 2 of 3 Samsung Jack Keyboard Replacement: step 4, image 3 of 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Keyboard Replacement: step 5, image 1 of 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Keyboard Replacement, Antenna: step 6, image 1 of 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Keyboard Replacement: step 7, image 1 of 3 Samsung Jack Keyboard Replacement: step 7, image 2 of 3 Samsung Jack Keyboard Replacement: step 7, image 3 of 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
  8. Samsung Jack Keyboard Replacement, Speaker: step 8, image 1 of 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  9. Samsung Jack Keyboard Replacement: step 9, image 1 of 2 Samsung Jack Keyboard Replacement: step 9, image 2 of 2
    • Use the spudger to detach the speaker ribbon cable.
  10. Samsung Jack Keyboard Replacement: step 10, image 1 of 1
    • Lift the speaker out of its compartment.
  11. Samsung Jack Keyboard Replacement, Motherboard: step 11, image 1 of 1
    • Remove the power and volume buttons on the right side of the Motherboard.
  12. Samsung Jack Keyboard Replacement: step 12, image 1 of 2 Samsung Jack Keyboard Replacement: step 12, image 2 of 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  13. Samsung Jack Keyboard Replacement: step 13, image 1 of 2 Samsung Jack Keyboard Replacement: step 13, image 2 of 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  14. Samsung Jack Keyboard Replacement: step 14, image 1 of 3 Samsung Jack Keyboard Replacement: step 14, image 2 of 3 Samsung Jack Keyboard Replacement: step 14, image 3 of 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  15. Samsung Jack Keyboard Replacement: step 15, image 1 of 2 Samsung Jack Keyboard Replacement: step 15, image 2 of 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  16. Samsung Jack Keyboard Replacement: step 16, image 1 of 1
    • Lift the Motherboard off of the phone.
  17. Samsung Jack Keyboard Replacement, Keyboard: step 17, image 1 of 3 Samsung Jack Keyboard Replacement, Keyboard: step 17, image 2 of 3 Samsung Jack Keyboard Replacement, Keyboard: step 17, image 3 of 3
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
  18. Samsung Jack Keyboard Replacement: step 18, image 1 of 2 Samsung Jack Keyboard Replacement: step 18, image 2 of 2
    • Lift up the LCD frame.
  19. Samsung Jack Keyboard Replacement: step 19, image 1 of 3 Samsung Jack Keyboard Replacement: step 19, image 2 of 3 Samsung Jack Keyboard Replacement: step 19, image 3 of 3
    • The keyboard ribbon cable passes through the LCD frame. Be careful not to rip the ribbon cable when removing the keyboard.
    • The keyboard and directional keys are glued separately to the LCD frame.
    • Insert the spudger between the keyboard and the frame.
    • Peel the keyboard off by sliding the spudger back and forth across the LCD frame.
  20. Samsung Jack Keyboard Replacement: step 20, image 1 of 3 Samsung Jack Keyboard Replacement: step 20, image 2 of 3 Samsung Jack Keyboard Replacement: step 20, image 3 of 3
    • Insert the spudger between the directional keys and the frame.
    • Peel the directional keys off by sliding the spudger back and forth across the LCD frame.
Jaime Serrano
59 Reputation
2 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,076
