Samsung Jack Motherboard Replacement
  1. Samsung Jack Motherboard Replacement, Battery: step 1, image 1 of 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Motherboard Replacement: step 2, image 1 of 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Motherboard Replacement, Rear Case: step 3, image 1 of 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Motherboard Replacement: step 4, image 1 of 3 Samsung Jack Motherboard Replacement: step 4, image 2 of 3 Samsung Jack Motherboard Replacement: step 4, image 3 of 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Motherboard Replacement: step 5, image 1 of 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Motherboard Replacement, Speaker: step 6, image 1 of 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Motherboard Replacement: step 7, image 1 of 2 Samsung Jack Motherboard Replacement: step 7, image 2 of 2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Motherboard Replacement: step 8, image 1 of 1
    • Lift the speaker out of its compartment.
  9. Samsung Jack Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Remove the power and volume buttons on the right side of the Motherboard.
  10. Samsung Jack Motherboard Replacement: step 10, image 1 of 2 Samsung Jack Motherboard Replacement: step 10, image 2 of 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  11. Samsung Jack Motherboard Replacement: step 11, image 1 of 2 Samsung Jack Motherboard Replacement: step 11, image 2 of 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  12. Samsung Jack Motherboard Replacement: step 12, image 1 of 3 Samsung Jack Motherboard Replacement: step 12, image 2 of 3 Samsung Jack Motherboard Replacement: step 12, image 3 of 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  13. Samsung Jack Motherboard Replacement: step 13, image 1 of 2 Samsung Jack Motherboard Replacement: step 13, image 2 of 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  14. Samsung Jack Motherboard Replacement: step 14, image 1 of 1
    • Lift the Motherboard off of the phone.
Jaime Serrano
59 Reputation
2 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 35
All Time: 2,310
