Samsung Jack Speaker Replacement
  1. Samsung Jack Speaker Replacement, Battery: step 1, image 1 of 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: step 2, image 1 of 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: step 3, image 1 of 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: step 4, image 1 of 3 Samsung Jack Speaker Replacement: step 4, image 2 of 3 Samsung Jack Speaker Replacement: step 4, image 3 of 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: step 5, image 1 of 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: step 6, image 1 of 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: step 7, image 1 of 2 Samsung Jack Speaker Replacement: step 7, image 2 of 2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: step 8, image 1 of 1
    • Lift the speaker out of its compartment.
Paul Piller
56 Reputation
5 Guides authored
Cal Poly, Team 24-57, Amido Spring 2011 Member of Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,743
