Samsung ML2510 Side Cooling Fan Replacement
  1. Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement, Removing Samsung ML2510 Back Panel: step 1, image 3 of 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Samsung ML2510 Side Cooling Fan Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Samsung ML2510 Side Cooling Fan Replacement: step 3, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 3, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 3, image 3 of 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
  4. Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement, Side Cooling Fan: step 4, image 3 of 3
    • Locate the holes on the panel that are attached to the main body.
    • Remove the front panel by gently moving the holes from the pegs one by one.
  5. Samsung ML2510 Side Cooling Fan Replacement: step 5, image 1 of 1
    • Using a Phillips #2 screwdriver, remove the two 1" screws on the front face of the printer.
  6. Samsung ML2510 Side Cooling Fan Replacement: step 6, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 6, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 6, image 3 of 3
    • Using a plastic opening tool, gently lift one side of the top panel from its peg.
    • Repeat process for the other side.
    • Lift the top panel from the front to remove it entirely.
  7. Samsung ML2510 Side Cooling Fan Replacement: step 7, image 1 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 7, image 2 of 3 Samsung ML2510 Side Cooling Fan Replacement: step 7, image 3 of 3
    • Lift the right side-panel up from the raised stops.
    • Gently rotate the panel as indicated in the picture to remove the panel entirely.
  8. Samsung ML2510 Side Cooling Fan Replacement: step 8, image 1 of 1
    • Poke out the side fan from the inside of the printer.
  9. Samsung ML2510 Side Cooling Fan Replacement: step 9, image 1 of 1
    • Unplug the fan's wires from the side circuit board.
    • Replace the fan and reassemble the printer using reverse procedures.
2 other people completed this guide.
bbaustin
268 Reputation
6 Guides authored
Cal Poly, Team 17-18, Regan Fall 2011 Member of Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 2,543
