Samsung Moment Camera Button Replacement
  1. Samsung Moment Camera Button Replacement, Camera Button: step 1, image 1 of 3 Samsung Moment Camera Button Replacement, Camera Button: step 1, image 2 of 3 Samsung Moment Camera Button Replacement, Camera Button: step 1, image 3 of 3
    • Power off the phone using the "Power Button", the circular middle button in the center of the phone.
    • Locate the camera button on bottom right side of your phone
    • Remove the back panel of the phone by sliding the spudger along the edge of the phone. The rear plastic panel will snap off from the remainder of the phone.
  2. Samsung Moment Camera Button Replacement: step 2, image 1 of 1
    • Remove the battery from the phone by pulling up on the battery edge.
  3. Samsung Moment Camera Button Replacement: step 3, image 1 of 1
    • If you have not already removed the memory card, remove it by gently sliding it out of its holder.
  4. Samsung Moment Camera Button Replacement: step 4, image 1 of 3 Samsung Moment Camera Button Replacement: step 4, image 2 of 3 Samsung Moment Camera Button Replacement: step 4, image 3 of 3
    • Using the small Phillips #000 screw driver, remove the six screws from the back of the phone.
    • Using the spudger tool, separate the back housing from the phone.
    • While separating the back house from the phone, the three buttons (the volume, the speaker, and the camera button) might fall out. Be sure to keep track of these three buttons and use them for reassembly.
  5. Samsung Moment Camera Button Replacement: step 5, image 1 of 2 Samsung Moment Camera Button Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • If the camera button did not fall, carefully remove it using a pair of tweezers. At this point, you can replace the button with a new one.
Be sure to gently slide the memory card back in its holder.
3 other people completed this guide.
Allison Coffee
214 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 12
All Time: 769
