Samsung Moment Camera Replacement
  1. Samsung Moment Camera Replacement, Battery: step 1, image 1 of 1
    • Slide the back cover off the back of the phone to reveal the battery.
  2. Samsung Moment Camera Replacement: step 2, image 1 of 2 Samsung Moment Camera Replacement: step 2, image 2 of 2
    • Place a finger in one or both of the indents by the bottom of the battery. Then pull out to remove the battery from the phone.
  3. Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: step 3, image 1 of 2 Samsung Moment Camera Replacement, Samsung Moment Rear Case Disassembly: step 3, image 2 of 2
    • Identify and remove the 6 screws on the rear case of the phone.
  4. Samsung Moment Camera Replacement: step 4, image 1 of 2 Samsung Moment Camera Replacement: step 4, image 2 of 2
    • Using a spudger, separate the rear case of the phone from the front case.
  5. Samsung Moment Camera Replacement, Camera: step 5, image 1 of 1
    • Identify the phone's camera piece
  6. Samsung Moment Camera Replacement: step 6, image 1 of 1
    • Use a spudger to peel back the green processing chip, exposing the wires underneath. Identify the thin golden band which connects the camera to the rest of the phone.
  7. Samsung Moment Camera Replacement: step 7, image 1 of 1
    • Using the spudger, separate the golden band from its resting dock. It should come apart fairly easily, like undoing a bit of velcro. Once separated, the camera should slide out.
Steven Cooney
200 Reputation
1 Guide authored
Marist, Team 1-1, Laflen Spring 2016 Member of Marist, Team 1-1, Laflen Spring 2016
MARS-LAFLEN-S16S1G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 292
