Samsung Mythic SGH-a897 Camera Replacement
  1. Samsung Mythic SGH-a897 Camera Replacement, Battery: step 1, image 1 of 1
    • To remove the phone's back cover, slide your fingernail into the slit at the bottom of your phone.
  2. Samsung Mythic SGH-a897 Camera Replacement: step 2, image 1 of 1
    • Place your finger on either bottom corner of the battery slot and lift to remove the battery.
  3. Samsung Mythic SGH-a897 Camera Replacement, Rear Case: step 3, image 1 of 1
    • Using a Phillips #00 Screwdriver, remove the six 5 mm screws from the back casing of the phone.
  4. Samsung Mythic SGH-a897 Camera Replacement: step 4, image 1 of 1
    • Using the iFixit Opening Tool, insert the tool into the seam between the back case and the rest of the phone.
    • Working along the seam, pry the back casing from the phone.
  5. Samsung Mythic SGH-a897 Camera Replacement, Camera: step 5, image 1 of 2 Samsung Mythic SGH-a897 Camera Replacement, Camera: step 5, image 2 of 2
    • Carefully remove the camera by using the iFixit Tool to pry the camera cable from the motherboard.
    • Carefully remove the camera from the phone's motherboard.
Morgan Yost
46 Reputation
6 Guides authored
Cal Poly, Team 17-1, Regan Spring 2013 Member of Cal Poly, Team 17-1, Regan Spring 2013
CPSU-REGAN-S13S17G1
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 287
