Samsung N150 Plus Back Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. Samsung N150 Plus Back Panel Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer.
    • Disconnect the charging cable from the laptop.
    • Failure to unplug the cable could result in electric shock.
    • Flip the laptop upside down with the front face down on a flat surface.
  2. Samsung N150 Plus Back Panel Replacement: step 2, image 1 of 2 Samsung N150 Plus Back Panel Replacement: step 2, image 2 of 2
    • Slide the left and right switch to the "unlocked" position.
  3. Samsung N150 Plus Back Panel Replacement: step 3, image 1 of 2 Samsung N150 Plus Back Panel Replacement: step 3, image 2 of 2
    • While holding the left and right hand switches in the "unlocked" position, push the battery away from the computer.
  4. Samsung N150 Plus Back Panel Replacement, Back Panel: step 4, image 1 of 1
    • Using the Phillip's 00 screwdriver, unscrew the fourteen 7mm screws until the back panel comes loose.
  5. Samsung N150 Plus Back Panel Replacement: step 5, image 1 of 1
    • Using either the blue plastic opening tools or spudger tool, wedge one in between the back panel and the laptop.
    • Apply pressure upwards till the back panel pops off.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
  6. Samsung N150 Plus Back Panel Replacement: step 6, image 1 of 2 Samsung N150 Plus Back Panel Replacement: step 6, image 2 of 2
    • The computer should be open with the motherboard exposed and internal components exposed. You should now be able to access the Fan and RAM. There are more necessary steps to follow before accessing the screen and keyboard.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 150
